Hello again kids.
I am officially dissillusioned by SVCD (I guess it's oK for music vids) and so have opted to scrounge and sacrifice for a Panasonic AO3 DVD Burner. So, now I'm capturing some AVI's and I want to encode them to DVD NTSC format with TMPGEnc. I'm looking for opinions since I couldn't find any doing a search.
Constant Quality or 2-Pass VBR?
What is the highest bitrate I can use?
What bitrates are best to use for CQ or VBR (max, min, avg)?
I want to keep everything at the best quality possible. Thanks a lot for all your help. Have a nice day.
~HgRising
HgRising
Well first the maximum bitrate that you can use for a DVD according to the DVD Standards is 9000KB. I have run across some DVD's that go slightly higher then this but not by much.
Second you must use a GOP Sequence header of 1 per interval. You also must select a maximum of 18 frames in the GOP.
To your question of VBR or CQ. I have been using CQ on rippen DVD's with better results then VBR. Tmpgenc as you now will produce a log with the encoding. I noticed that the bitrate was lower then I wanted on the average even tho I had set it to say 5000kb. The average was always around 3000kb so I went to CQ and the log came back with 5000.1kb and a much nicer picture in less time.
You'll have to experiment with your .avi's tho.
audio encoding: tmgenc dvd author 3 vs. tmpgenc plus
By cL0N31 in forum Newbie / General discussionsReplies: 0Last Post: 6th Jan 2009, 23:25 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23 -
Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
By Hal05154 in forum Newbie / General discussionsReplies: 9Last Post: 25th Sep 2007, 13:13 -
TMPGEnc DVD Author 3 - Stopping it Re-encoding
By Incast in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2007, 17:45 -
QuickTime DVD Encoding With TMPGEnc
By bigscaryrobot in forum Authoring (DVD)Replies: 0Last Post: 26th Jun 2007, 15:26
