I'm using FAVC to create a DVD from 5 XVID files I have. I set everything up and it starts encoding just fine, but the finished product isn't what I would expect. Instead of creating a DVD with all 5 files, it is creating a DVD with only 2 of the files. The VOBs it produces are encodes of File 1, File 2, and a duplicate of File 2. That's it. It neglects the other 3 files I chose, and it creates a duplicate of the second file for some reason.
This is driving me crazy, because this program runs great on my 64bit system where others crashed. The encodes it produces look good too. Is there something I'm missing here? I can't understand why it would give such an odd result.
Can you play those files back correctly ? There have been several posts regarding corrupt file systems that lead to the selection of one video resulting in the playback of another.
You can also tell FAVC to create the scripts, then stop. You can then look at the scripts to see what it is doing.Read my blog here.
That's very odd.
First if you could check the scripts, as guns1inger says that would be good - they'll be in the working folder as Title0.avs, Title1.avs, etc. Check that the correct files are being referenced/opened in them.
Having trouble getting mkv to mpeg2 with FAVC
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 18:14 -
Favc
By sportflyer in forum Video ConversionReplies: 8Last Post: 19th Feb 2010, 20:20 -
Having trouble downloading FAVC
By chohmann in forum Newbie / General discussionsReplies: 10Last Post: 4th Apr 2009, 03:09 -
Trouble with FAVC
By Filraen in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2008, 02:22 -
help using FAVC
By eao1 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2008, 19:41
