i had this file with real poor quality when i played it on my cd player. i searched the net and d/l sony sound forge. tried improving the quality using eq / built in tools, quite ok. but when i tried saving the file in mp3 in 128 kbps CD qual audio the sys just hangs
is it not possible ? what am i doing wrong ?
Results 1 to 9 of 9
yes i can save and open m3p files but the moment i save as 128 kbps the s/ware hangs!
i already spent more than 5 attempts and over 2-3 hrs d/l sony s forge (44 mb) its really frustating not being able to use this s/ware
love the simplicity probably get into part time audio business as its ease of use is very high -
Crap in, crap out I'm afraid. You can not input a 64kbps file and save it at 128 expecting the quailty to improve.
Is this a demo version? Perhaps it's save-disabled for some formats.Originally Posted by sleazy70
And as I said, try exporting to WAVE. -
yes it is a demo version. whats the point in transferring to mp3 when my player recognises only audio/mp3 etc.
thanks -
The idea is: If you can save as wav do so, then convert the wav to mp3 at your desired bitrate (& cetera) using some external tool like lame.
/Mats -
You'll have a real job trying to bring back what has been lost forever as MP3 conversion strips 'unwanted' high frequencies, thats why people use high bitrates, you still lose the frequencies but not as much
Run a WAV file through a spectrum analyser then convert it to 64kbps MP3 and run it through again, and you can see what you have lost and thats what you're trying to replace
Have a look at this, they have a very good plug-in that I have used as a VST option with other editing software and it does a better job than others in trying to re-create those missing frequencies, it certainly made it sound better than it did when I played about with recirding from an online radio station that used 64kbps audio
http://www.acondigital.com/us_AcousticaPE.html
Also, the plug-in I used
http://www.acondigital.com/us_StudioClean_Features.html
What you want to look at is the StudioReBirth option
It does add back extra frequencies as I've compared poor MP3s before and after and it does go some way to trying to get back what MP3 conversion has stripped -
thanks i think the conversion mp3-wav-mp3 is a easier option shall try that first
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 09:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 14:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 08:46 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57
