I'm trying to convert a realmedia file to xvid using mencoder but the audio drifts to the point that there is a bad delay. Is there a way to fix this? Here's my command:
mencoder -ovc xvid -oac mp3lame -lameopts cbr -xvidencopts bitrate=800 -o test.avi input.rm
Results 1 to 10 of 10
This happens often with rm files. They usually can't be fixed.
Google is your Friend -
source info?
command output?
if I were to reach for Guns1inger's crystal ball, i think i'd see 3 words:
vfr -
I don't mind the VFR but I need to convert to cfr to watch on my hardware divx player.
I loath rm. It doesn't convert to anything without losing audio sync. I've tried lots of tools.
And there is some great stuff out on the net in rm format - including the Kennedy Center's Millenium concerts. DRM by technical incompetance. -
And how do you grab the Kennedy Center stream?
I might want to try.
ty -
The only time I needed to convert a .rmvb to a .divx,
I used Avisynth and VirtualDub. Worked for me.
Use AviSynth with 'fps=...' and 'convertFPS=true' options in DirectShowSource for proper handling video stream, otherwise in case of VFR nothing will help you to repair video/audio synch (even if you find sync points in the beginning and in the end and adjust audio length). You might still need adjusting delay in the beginning after encoding.
Unlikely you can do something like that with other tools. -
I use flashget. Sometimes have to capture then open a ram file.Originally Posted by 45tripp
Flashget is a wonderful free tool. Also can serve as a bittorent client.
Will run 6 simultaneous download streams from a site which supports download resume.
Loss of audio sync when compressing or converting DV files on Mac
By Sloperman in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2011, 09:26 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
How do I make Mencoder stop converting 3 - 10 files at once?
By gemasis in forum Video ConversionReplies: 3Last Post: 29th Dec 2008, 15:56 -
Problems converting files using either mencoder or ffmpeg
By krisbee in forum LinuxReplies: 12Last Post: 21st Sep 2007, 07:26
