Is cropping of video is possible in Divx Convertor or Divx Author????
I'm using Pro versions of both of them....
EDIT: I mean just the top and the bottom like in the screen shots.... the original r like this
I wanna crop the highlighted part...
And make the videos like this
Can anyone help me out???
Or if u know any other software which can convert x into .avi without losing the quality of the video.... pls let me know...![]()
Results 1 to 10 of 10
Thanks for replying.... is there any other codec which can prevent the quality loss???Originally Posted by guns1inger
There are lossless codecs, however the trade off is that they are only playable on your PC, and the files sizes are very large.
You can do Constant Quality encoding with Divx/Xvid, which will try to make the results visually identical, but you have no control over the file size. Start with some tests and see if you can find a balance.Read my blog here.
Thanks again guns1inger..... now here's the last question.... I got full DVD og live concert of Eminem and I was thinking to convert it in avi format.... when I was just about to start encoding I noticed that in the DVD the concert is in 3 vob files.... 2 of 0.99 GB & 1 of 842 MB how to encode them in single avi file???
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 20:28 -
Xilisoft DVD to Divx Convertor
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2008, 15:23 -
hd -> divx using divx convertor
By uk_dan2k in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 16:57 -
DIVX convertor / resolution
By surfer in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 04:56
