I ripped a DVD which has two aspect ratios:
1)Standard
2)Widescreen
I opened the vob files in DVD2AVI and the aspect ratio was 4:3. I tried to get to be 16:9 but with no luck. I can get 16:9 flaskmpeg but I want to encode using nandub. Is there a way to change aspect rations in DVD2AVI??
Different aspect ratios are contained in different VOBs. You need to rip the other set of VOBs. Smartripper should tell you the aspect ratio of the title you're ripping.
Alienz
Like kinneera said different vobs have different aspects. Usually the first vob of the movie which contains the menu "VTS_0x_0.VOB" has a 4:3 aspect and the movie itself after that vob "VTS_0x_1.VOB". is in 16:9.
When you use DVD2avi to frame serve to tmpgenc select the "VTS_0x_1.VOB". DVD2avi will automaticly select all the following vobs of the movie.
You then save your project as normal select which track of audio to demux and set tmpgenc up to encode it for you.
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 13:30 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 07:21
