I download what was supposed to be an ISO but instead i recieved a folder with .I00-.I09 files how do i burn these to a dvd or make an iso with them?
Results 1 to 30 of 32
can't you open it in dvd shrink and then output to an iso?
did you open the .mds? if you have no mds file I don't know what you can do.
Yes I tried opeaning the mds file and that is when it said that the file format is invalid.
Can you open it in dvd decrypter without problems?
You can also try mount it as a virtual dvd with daemon tools, make an iso with imgburn. -
You can also try mount it as a virtual dvd with daemon tools, then extract the video_ts folder.
Maybe it's a splitted file. Look for a program that can merge all these files to a big one or maybe you can try to open the first file with Winrar.
Ill try to mount it with daemon tools and dvddecrypter can't even open the file and it has a mds file but when i tried to mount it with alcohol it couldnt and when i tried to open it with winrar i got the video folder but it was too small it was about 600mb.
Looks like ISO file was split into 10 pieces
by program similar to HJ split -
Yep, it could be that also. But doesn't dvd decrypter / imgburn also split to mds / i00 files? maybe not 10 files for 6gb though.
t_jay17 wants to shrink it before burning.
t_jay17: http://www.freebyte.com/hjsplit/ -
maybe give us a little more informatoin. what is the error msg? If it's in use see http://www.softwarepatch.com/tips/howto-delete-xp.html
It says, This action can't be completed because the file is open in another program. Close the file and try again.
Unlocker 1.8.5
Publisher's Description:
Unlocker is a Windows Explorer extension allowing you with a simple right-click on a file or folder to get rid of error message such as error deleting file or folder, cannot delete folder: it's being used by another person or program. Simply right click the folder or file and select Unlocker. If the folder or file is locked, a window listing of lockers will appear. Select the lockers and click Unlock and you are done.
http://fileforum.betanews.com/detail/Unlocker/1115825635/1 -
I have somehow similar problems. During the last many months i have stored a lot of my DVDs on my harddisk, and recently i wanted to burn a copy. I have used the programme DVDFab to store it, but i just found out that this programme can't burn copies. I saw that the DVD i was trying to burn contained some I00 or I01 files and a MDS file. I was then advised to google the "I" files, and then i stumbled upon this thread. Here i saw that i could try to burn through imgburn, which actually helped. I will say a BIG THANK YOU FOR THIS!!
However i have another problem: I am trying to burn a copy of one of my Elton John DVDs, which contain an AUDIO_TS folder (which is empty) and a VIDEO_TS folder, which contains a LOT of files! Just to name a some: VIDEO_TS.BUP, VIDEO_TS.IFO, VTS_01_0.BUP, VTS_01_0.IFO, VTS_01_0.VOB, VTS_01_1.VOB. After this the numbers change until 06_1, always changing between VOB, IFO and BUP. There are a complete of 28 files.
Can anyone tell me how i can burn a copy of this? PLEASE explain it very detailed, because although i am very far from brandnew in dealing with computers, i have always had HUGE difficulties in learning new stuff.
Jan -
No, it doesn't work. I already tried this before i wrote here, but the result was an empty disc!
Jan -
Thanks a lot!! I really believe that that is the answer to my problem.
Now one final question (at least i hope so): Is there any way that i can see on the files, or on my DVD if it is copy protected, so that i can't burn what i have saved on harddisk through DVDFab? At best i prefer to be able to see it on the files, because some of my DVDs lie in another part of Denmark, and i won't get there for some time.
Thanks again for your great help!
Jan -
My problem grows more and more weird...
I just tried to take a copy of a U2 concert, which i once recorded in the television on a VHS tape. This is of course NOT copy-protected!
Like all the other DVDs i have stored this through DVDFab on my harddisk.
Now i wanted to burn a copy through imgburn, using build mode, and then opening for the audio and the video file. But the result was an empty disc! Why?
Yesterday i asked exactly the same question in another thread, and the answer was, that i had used a copy-protected disc, which i believed, but this time my source VERY clearly isn't copy-protected!
So...how can i solve this?
Since i don't feel too sure where people are gonna read, i will pose the same question in my other thread, which i hope is ok. If not, i guess some moderator has to choose which one to erase.
Jan
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
DVDShrink cannot open *.i00 file
By Leo48 in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2009, 17:00 -
Converting I00, I01, I02 etc
By absurdism in forum Newbie / General discussionsReplies: 7Last Post: 30th Jun 2008, 20:21 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 04:50 -
Making an Iso from an I00 file
By t_jay17 in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 16:50
