  1. Is it possible to change the aspect of the Menu (4:3 / 16:9)
    I made a menu with images but when the default 4:3 setup is shown on a widescreen tv
    everything is stretched wider than it should be.
    If it isn't possible to make 16:9 menus, I would like to see the option in future builds.
    Ta much
    Meeky
    Apr 2003
    Get version 2.5.3200
    Recent updates include:
    * Widescreen DVD Menus
    * Support for DVR-MS files
    * Support for x264 and h264 video
    * Support for matroska (.mkv) files
    * Support for AviSynth script files
    * Improved NTSC-Film and PAL to NTSC conversions
    * Massive speed increase over v2.1 - upto 60%
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Obviously you need to have your backgrounds in the appropriate aspect ratio too...
  4. Thankx for the update.
    Just back from my hols and missed the upgrade.
