Hi All
I'm looking to digitise my vast collection of VHS tapes from 1990 onwards into AVI format on my Archos AV500 or something similiar.
As its a 3hrs tape and there's several shows per tape, what app would I use to trim out the extra and cut them up?
There's a great app called MP3 trimmer for the Mac which I used for old cassette tapes, basically need something like that for avi's.
cheers
M
Explicit AVI Cutter does exactly what you want, splitting, and nothing more.
MPEG Streamclip has loads of features, one of them saving a selection. -
How are you actually digitalizing the tapes? Your previous post indicated you were using a DVD recorder (and finding out that it all happens in real time!). If so, then doesn't it have a Divide feature, so that after transferring a tape to the internal DVD recorder harddrive, you can break it into separate programs? But you're in for a hellava lot of work, then recording them as distinct episodes to the one DVD disc, then reading from the DVD by, and using, MPegstreamClip to convert each (but as a batch) to AVi before you can transfer to Archos.
Hi
I can digitise and put stuff on DVD with the Lite On, which too date i've only done a few of.
The archos is another route for direct AVI recording. Thats what the apps would be for.
I may end up sorting through the tapes and break them into three groups - dump, DivX and DVD-record. Based on content.
M -
Hello all,
I am facing a same kind of 'problem' as blackice, only for Windows not MAC
Could I use the suggested Explicit AVI cutter for that?
If not, I am looking for a free program (might VirtualDub be a good program?) what I can use to trim original AVI files , by taking bad scenes / parts away....
Another person in the States is going to use those AVI's and edit them to a final product.
Thanks for the input!
Very long AVI to mpeg
By Sparkydjm in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2011, 05:45 -
Virtualdub or Virtualdubmod for DV AVI trimming?
By sasuweh in forum Video ConversionReplies: 8Last Post: 19th Oct 2010, 22:31 -
Trimming AVI in virtualdub,direct strem copy ignores my start and end point
By Rudyard in forum EditingReplies: 4Last Post: 4th Oct 2010, 20:11 -
How long does it take to make a DVD to AVI?
By iamkatpeeler in forum Newbie / General discussionsReplies: 6Last Post: 24th Jan 2009, 02:08 -
AVI - Lossless Trimming
By tripecac in forum EditingReplies: 14Last Post: 4th Jul 2008, 03:03
