I'm very happy with VLC after finding the wonderful skins that were made for it.
I've had quite a bit of problems on my pc in dealing with external codecs.
So, is there any reason I should consider keeping MPC on my pc?
I'm so excited to delete divx, xvid, real, and quicktime alternative.
Results 1 to 9 of 9
I still keep VLC around for 'odd' formats and all the other things like transcoding and streaming. But I am using KMPlayer now for regular playback instead. It handles ISOs, DVD files like VLC and has the volume control on the mouse wheel. It also has an easy on-screen slider for sync adjustment. I definitely like it better than MPC. And it's easier to configure for most uses than is VLC.
Here's one. VLC is 'too good', I recently tested a DVD backup (before burning) that had not been properly decrypted. VLC played it without a problem, MPC did not. Now imagine there were no MPC (1MB and no installation needed) in addition to VLC: at least one DVDR lost. Similar problems can occur with testing e.g. quality of your own encodings for DVD, etc.Originally Posted by majax79
Google is your Friend
Just to add my little .02 and add to Alex_ander's comment.Originally Posted by Alex_ander
MPC is useful for checking out other types of video files also. As stated before VLC is sometimes "too good", playing just about anything thrown at it. However, if you ever plan to share your files it may be a good idea to try it in MPC to make sure the file is within "specs" for playback on other PCs.
It may very well be a codec glitch or a VLC setting that's not right, but I've had some files in the past not play in VLC, but would work in MPC. As I recall, corrupted avi's (probably divx or xvid) and WMV, ASF files.
I just did a quick test right now and none of my WMVs or ASFs will play in VLC (no picture), but will play fine in MPC.
The way I figure things, MPC isn't taking any space worth mentioning and doesn't even require installation. It's a tool in the toolbox that I may not need it...but it's nice knowing it's there!
lingyi wrote "The way I figure things, MPC isn't taking any space worth mentioning and doesn't even require installation. It's a tool in the toolbox that I may not need it...but it's nice knowing it's there!...
" Who needs Google, my wife knows everything"
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
Delete display of running time
By tonwark in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2008, 12:53
