Hi Guys,
Do you know of any program in the range from free to $100-150 which can encode .wav files into AC-3 for putting onto DVD? I read that audio in this format will save you a lot of space on the DVD. DVDit PE and ReelDVD do that conversion, but are quite expensive.
Thank you and best of luck,
Luby. -
or you could convert to mpeg1 audio layer2 but not all authoring tools support that. The only ac3 tool I have seen is sonic foundry soft encoder but it has been discontinued.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 20:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 14:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
