I have hours and hours of lecture notes I'd like to burn onto CD but the problem is that I don't want a single 65 or 70 minute track. Is there a utility I can use to automatically cut large wav files into a specified number of chunks? Or into chunks of a specified length (say 5 minutes)?
Thanks all!
http://encoding.n3.net <-- for all your DVD and CD backup needs!
right... but isn't that manual is the sense that I have to shot it cut points? I'm looking for something that'll do it automatically preferable from the command line so I don't have to mess w/ a GUI.
http://encoding.n3.net <-- for all your DVD and CD backup needs! -
Guess I missed the "automatically" part...good luck!!!!
" Who needs Google, my wife knows everything" -
MP3DirectCut looks like it can do what you need.
You can get it from http://www.mpesch3.de
Open your file
Click on Special, then Auto Cue. There you can set the minute intervals. I set it to 5 minutes.
Next, click on File, then Save Split. That will create several files of the specified length.
It's not a command line method, but is very simple.
HTH
Edit:
Oh, darn. just noticed you said they were wav files. This can't open wav files, but, you could use Audacity to convert your files to mp3, then use MP3DirectCut to split them. But then you would probably want the split files as wav files. Oh, well. -
I'll bet Sox can do it. Not sure of the syntax, but there should be examples out there.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 09:37 -
Question why captured stream comes in 5 minute chunks
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jun 2009, 22:17 -
cutting a large WMV - audo/video sync is off
By djbryson in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38 -
"chunks" cannot get my .VOB file to split into .DV chunks
By system9 in forum ffmpegX general discussionReplies: 2Last Post: 12th May 2007, 17:53
