I have a home dvd of family events…wanted to create a menu with some pictures and features. So I ripped the dvd…it came out in Video_TS folder with vobs and IFO files.
Now the experiment started, good grief, I have dvd + rw, I try to burnt again using Nero features but did not succeeded….and if I burn vobs with DvdShrink…it is impossible to create menu and feature .
The question is how could I make menu? And the second question is…how could I add the vobs files in nero? For example in video_ts folder there are 10 files starting form
VIDEO_TS
VTS_01_0 to Vts_01_5
Vts_02_1
Vts_03_1
Vts_04_1
quite funny for many here!!
Results 1 to 9 of 9
tmpgenc dvd author, ulead dvd moviefactory, ulead dvd workshop, etc can import from dvds and then you make a menu.
if you are looking for free tools you can use guifordvdauthor, but first split the video and audio from the dvd vobs with pgcdemux and import the video and audio files in guifordvdauthor and make the menus. -
Originally Posted by Baldrick
how could i bring the files in tmpenc dvd author or ulead moviefactory....as i mentioend earlier there are more than 10 files...which file i am looking to insert in that programs. Do i have to insert all 10 files? I do have both programs, tmpenc dvd and ulead movie factory.
I wish to have a family picture in the main manue..than some ft. i did it with some files...but those were avi...this is vob and were try with them but unable. -
Baldrick....i tried with Ulead moviefactory, ulead did not recognise vob formate. It is saying "unable to open the files"
Looks like you need help on VIDEO_TS file structures.
Just go here ............ https://www.videohelp.com/glossary?V#VIDEO_TS
and make sure you click on the last word in the VIDEO_TS paragraph which is "here"
to get full info. -
Originally Posted by bendixG15
VTS_01_0.IFO = Title 01, IFO, usually the main movie
so what if i only load this file which carries main movie?
so could i load only this file to make dvd? or do i have to load other. -
Originally Posted by t0nee1
btw....thank you very much.
How to cut VOB-file and create DVD from VOBs?
By john999UPR in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2009, 10:07 -
Create DVD from several VOBs ?
By flash70 in forum DVD RippingReplies: 3Last Post: 8th Jun 2008, 09:51 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 16:26 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 12:22
