Hey Folks,
I've been experimenting with DVD creation for a while now, and so far it's been pretty simple. I've recently finished capturing a set of old tv shows we like, and I want to burn them to dvd, with a menu, for easy viewing.
I have the TMPGEnc programs to re-encode if necessary and to author the dvd.
1) CAN I re-encode these files (mpeg-2 704x480, 23.976 fps, 4:3 ratio) to maxamize the number of show I can place on a dvd? Right now I can do 3 or 4 shows per dvd. WMV perhaps?
2) When I import files in DVD Author, can I capture the file name in the menu somehow?
I appreciate the help. Pointing towards guides is always appreciated.
Hal
Results 1 to 10 of 10
Hi,
An alternative would be to convert them to divx or xvid if your player can handle that. However only divx ultra players can support divx menus.
The other part of your question is yes you can reencode the video to lower bitrates to lower the file size. You can use an mpeg encoder like tmpgnec plus to change the bitrate to a lower level to squeeze more onto the disc.
Another part to this question is do you have a dual layer dvd burner? If so buy dual layer discs and you can fit 8gigs instead of 4gigs on the dvd. Double the capacity essentially.
I hope I'm not making this sound more complicated than you were looking for. I'm trying to be thorough in my response. Please feel free to ask specifics if you are unsure about something. I or another member here will be able to help flesh out the detail a little more.
Good luck and don't be afraid to experiment. Remember rewritable discs are a great way to test new ideas without wasting discs.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Your responses were great. I'm new to the TMPGEnc products, so I am still experimenting. One more question. If I lower bitrates to lower the file size, do you have preference to the best reduction with still the best quality?
Just for those that are curious why I don't just use multiple dvds, I would, but I have young children and want to minimize how much the littlest ones mess with my dvd player. More shows per disk, less fussing with the disks.
Thanks for all the help!I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone. -
You can use VideoHelp Bitrate Calculator from this web site to check how many episodes you can fit on DVD. It depends how big is your TV. Bigger = larger bitrate. I would not go bellow 3000kbs and use VBR to encode Mpeg file with TMPGEnc Plus.
OK, well, now I feel dumb as a box of rocks...
My re-encoded file is 1.5 gigs in size. What the heck is up with THAT? HA!
The originals are nowhere near that big. But that might not mean anything in regard to how they are processed to a dvd, right?
Can anyone point me to a good TMPGEnc tutorial please....
HalI'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone. -
If you are encoding at VCD resolution, then 1000 - 1500 might be acceptable.
If you are encoding at half-D1 then you can use 2500 - 3000.
If you are encoding at full-D1 then you need to keep it above 4000 or you will get artifacts.
You also need to remember that VHS is noisy, and noise eats bitrate. The noisier the source, the higher the bitrate needs to be avoid artifacts.Read my blog here.
If you have DVD Author 2 or 3, you can go into their preferences > Project default settings and tell it to display clipname as chapter names + number so you don't have to manually type in each chapter. Might have to restart program for changes to take effect.
Also, with TMPG 2.5 Plus, you can use their noise and ghost filter to help reduce those VHS noises. Might want to do all that and re-encode to 1500kbps before you author to DVD.
Request for allin one software advice please
By Ian Shaw in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2008, 20:50 -
Advanced DVD menu creation in TMPGEnc DVD Author 2.0
By roma_turok in forum User guidesReplies: 45Last Post: 23rd Jul 2007, 11:11 -
Newb h264 or codec advice request
By EAO in forum Newbie / General discussionsReplies: 14Last Post: 2nd Jul 2007, 00:18 -
request advice concerning undelete files accidentally lost.
By kasfig in forum Off topicReplies: 5Last Post: 21st May 2007, 15:19 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 18:27
