is it possible to view them b4 joining and if so with what,i use hj split for joining
thanks for any advice received
Results 1 to 11 of 11
virtualdub, video->direct stream copy and audio->direct stream copy, cut, save.
I was just about to post a msg about the operation of this program, so that's what I'll do. I want to split an avi file nearly in half so that I can get each part onto a DVD. The total length is about 8.3G. I just deleted (Delete in Edit menu after setting the begin/end markers) the second part (1/2 roughly, 4.2G) and am now saving ghe file as an avi file. It's slow. In fact, it's odd. It seems to be producing a file greatly in excess of the 4.2. What's going on?
solarblast wrote:
As Baldrick said,I just deleted (Delete in Edit menu after setting the begin/end markers) the second part (1/2 roughly, 4.2G) and am now saving ghe file as an avi file. It's slow. In fact, it's odd. It seems to be producing a file greatly in excess of the 4.2. What's going on?
\\\\\\\\\\\\\\\\\video->direct stream copy and audio->direct stream -
Somehow I don't think Virtualdub is suitable for simple slicing of avi. I finally accomplished what I needed on this matter by just slicing and dicing an avi file with Vegas, and then rendering them to avi. A little clumsy, but it works.
Not if it reencoded the whole thing, it didn't work....and then rendering them to avi.
copy.Originally Posted by solarblast
Or read a guide, https://www.videohelp.com/guides/how-to-cut-an-avi-file-in-smaller-parts-id357#357
Thanks for the link. Next time out on avi splits, I'll see how this works.
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 22:42 -
split/join avi files without recompression
By Jan G. in forum EditingReplies: 3Last Post: 20th Dec 2008, 13:54 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
