I used AutoGK to shrink a dvd to cd size. The first time, I ended up with ~0.5 second delay between the mouth movement and the speech. I did another one and got a whopping 32 second delay.
What the heck is going on?????
Yeah, did you decrypt using DVD Decrypter in IFO Mode, rather than File Mode? If not, try that. And if it's a newer DVD with extra copy protection, then you'd best use RipIt4Me to decrypt it, Movie Only.
And if decrypting properly doesn't help, and if it's a fixed asynch (off by the same amount all the way through), then fix it by adjusting the delay in VDubMod. -
I use DVD-Cloner IV to rip to my hd (I stupidly paid for a program before I found the freeware!). I've ripped quite a few and burned copies with Nero Burn and ImgBurn - all of the copies have worked perfectly, even the dvd9 one-to-ones.
Could the problem have anything to do with the original dvd itself??? The first one had everything - movie, menu, extras, previews, etc. all in one vob set, so I used VobBlanker to pick out the movie then the extra feature I wanted to shrink. That one was off only slightly. The second dvd had all the menu items stuck on the front of the vob set, so they flashed by quickly in the shrink. This is the one that was off by 30 seconds! -
Intensity Pro Gradually Desyncs in capture apps, please help!
By swiftor in forum Capturing and VCRReplies: 5Last Post: 30th Aug 2010, 19:50 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
Audio desync in Autogk
By godfist314 in forum DVD RippingReplies: 3Last Post: 5th Sep 2008, 10:22 -
autogk, audio out of sync
By Disa in forum DVD RippingReplies: 2Last Post: 30th May 2007, 15:03 -
autoGK subtitle out-of-sync with audio?
By cristolin in forum SubtitleReplies: 0Last Post: 16th May 2007, 00:14
