Never tried it, but if none of our members can assist, you could try the DOSBox site: http://dosbox.sourceforge.net/information.php?page=0 or their forums: http://vogons.zetafleet.com/viewforum.php?f=31&sid=fc5c1b5f83ed08cdb9e0e5a170b5c164
But your syntax looks wrong. It probably should have been: C:\>cd C:\games
But I haven't used DOS in a while. -
I suspect the problem is that you've mounted C:\games on your hard drive as C:\ in DosBox. So you don't need to CD to the games folder, you're already there. Type DIR to see the contents of the drive. It should be the same as C:\games on the host.
If you need access to other stuff on the C: drive of the host you should "mount c c:\" instead. Then you will have to CD GAMES to get into the games folder. -
You may want to try one of the frontends available from the DosBox site. I like going command-line most of the time, but the frontend takes all the hassle out of it (especially if you're just playing games0.
Not working for me...
By Carita in forum ffmpegX general discussionReplies: 10Last Post: 20th Apr 2011, 00:02 -
Wi-Fi Not working on new laptop
By Squid_uk in forum ComputerReplies: 18Last Post: 18th Dec 2010, 21:51 -
sound not working
By hardy in forum ComputerReplies: 1Last Post: 20th Aug 2010, 02:47 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
DV not working
By mainegate in forum ffmpegX general discussionReplies: 9Last Post: 23rd Aug 2007, 19:04
