I just did a stressed out job where i extracted an m2v in dgindex and wanted to mux in another wave audio file and burn back to dvd. Problem was, the video was from a DVD recorder set in EP mode which generates half-d1 video.
Adobe Encore only supported 720x576 so I am currently transcoding+burning the video (2,2hrs) in Premiere and it's taking ages, putting a large production behind schedule =) What would be the fastest way to do this without transcoding? Also, compressing the wave to a more manageable format in the process would be needed to fit the data back onto a disc.
dvd-lab, tmpgenc dvd author. You can compress the wav to ac3 with an external converter.
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 12:58 -
Authoring Software that supports h.264
By sampalmer21 in forum Authoring (Blu-ray)Replies: 1Last Post: 3rd Nov 2009, 10:17 -
Which DVD authoring application is good at seamless branching?
By AnitaPeterson in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 22:03 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
Basic Application to create .psd buttons for Authoring?
By Moontrash in forum Authoring (DVD)Replies: 12Last Post: 24th May 2007, 07:12
