    Dec 2002
    I have a problem with my ipod or itunes, whenever i try to tranfser anything from the PC to the IPOD (4G photo) the file transfers, then i tunes starts to sync the ipod to the PC, and then wont stop. so i have to CTRL/ALT/DEL the PC to stop itunes running, Can anyone suggest whats wrong..............
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    You might check the following (all of these settings require you to have your iPod connected, though):
    On the iPod Summary tab (from the left window, LIBRARY > DEVICES > (your iPod's name), or it'll automatically be selected when your iPod is connected):
    Is the "Manually manage music" box selected? If not, iTunes will attempt to synchronize its library with the one on the iPod. "Enable disk use" couldn't hurt, either, but that's a different story.
    Next, on the Music tab, there should be a checkbox for "Sync music".
    On the Podcasts tab, there should be a "Sync" checkbox with a dropdown.
    Finally, on the Contacts tab, you'll see two Sync checkboxes. For Contacts, it's "Sync contacts from:", and for Calendars, it's "Sync calendars from Microsoft Outlook." See if the behavior continues if all of these boxes aren't enabled.
    Dec 2002
    None of these boxes are ticked, only the manulayy manage music one, Ans even though i have reinstalled itunes, the program still insists on syncing. and i cant get it to stop!!, thanks for replying though
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Hmm... does it do that anytime you try to transfer something to your iPod?
    Have you noticed your iPod acting strange in any way? I believe (as I'm not at a computer that has iTunes installed at the moment, so I can't check) there should be an option to verify the iPod's working correctly in the Help menu.
    Dec 2002
    I have RESET my pod and also reinstalled the original ITUNES that came with the ipod, and fingers crossed all is ok. Thanks again for helping me out
