How do I check my dvd's framereate?
DVD Decrypter will tell you if it's 25 or 29.97fps, select the dvd drive and check at the bottom right( I guess).
Or open a vob file from the main movie(usually any of the 1GB vob files) from the dvd with mediainfo or gspot.
Or if you want to know if it's 24 fps or mixed interlace/progressive you can use dgindex and load the main vob file and use the preview.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
Variable FRAMErate dvd demuxing
By gbi in forum Video ConversionReplies: 8Last Post: 11th May 2009, 07:24 -
How to confirm the DVD framerate?
By chiappa in forum MacReplies: 5Last Post: 3rd Jan 2008, 04:59 -
Having framerate issues converting to DVD
By MikeCouves in forum ffmpegX general discussionReplies: 17Last Post: 4th Oct 2007, 20:17
