OK this is gonna be hard to explain but Ill try to explain it as best as I can for you all in hope you can help me!
Ive got this DVD-5
first it plays perfect on the PC HD all the VOBS play fine.. burns fine and all
There is 4 titles 1 is the movie and 3 others are extras.. im not to worried about
I have no idea what was done to create these VOB files either
now when I play the movie in any DVD player in the house (tryed about 4) I have a slight annoying pause pretty much in between every chapter!!
I tryed to use Vob Blanker I tryed to re auther and still the same thing./. what is interesting is these Vobs dont pause when I play them on the HD though.
now what is even more interesting is for example I use TMPEnc re auther.. now when I selected DVD video and chose the Video folder its in and chose track 1 (which is 1 hr 20 mins) and I go into the editing thing and it does its scan,.. only 3 mins of the movie comes up!! where has the other 77 mins gone
so it looks like whoever has done this has done it some very wierd way where its divided in chapters. whcih would explain why there is pauses throughout the entire movie. yet it doesnt explain why the title is 1 hour and 20 mins the entire movie! I am confused out of my mind here! I would have thought if it was done this way that there would be about 50 titles
I even tryed to re author in Shrink then use TMPGEnc again and still it would only show up the first 3 mins of the movie not the entire track 1 which is 80mins
Can anyone help me out with this?? greatly appreciated
Results 1 to 15 of 15
Hi....
If you want to get the movie right you can try this..
It can be a little advanced...
Demux the main movie with DGIndex or you can use projectx (req. Java Runtime).
Now you have the main title divided into video .m2v audio .ac3 or mp2 and the subtitles .sup
Reauthor a new DVD with guifordvdauthor.
The chapters will be lost but you can insert new with the authoring program.
There is no need to re encode the movie. The extras will be lost....
stars.... -
You have probably mapped the end-of-chapter to go to the next chapter. When you do this, you get this jump. Always leave end-of-chapter mappings blank within a title set. When you do, it will seemlessly continue to the next chapter. About the only end-of-chapter that you do map is the last one, which you map to go to your menu, next video, etc.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
This happened to me couple of times when I used a DVD recorder to record some karaoke songs from the internet. It played fine in all DVD players I have. I wanted to reauthor it because some songs were not complete. But DVD Shrink and TDA could only find a few titles. I gave up. After many months, I tried it again with TDA. It's a miracle. It showed all titles albeit even duplicated them! So if I have 30 songs, it was showing 60 titles. It looked like my single layer DVD could accomodate more than 8GB of data. Probably an illusion.Originally Posted by Adster
I am just telling you are not alone with this kind of problem. Hope somedoby can explain it to us. -
Perhaps the movie has been encoded with long GOPs.now when I play the movie in any DVD player in the house (tryed about 4) I have a slight annoying pause pretty much in between every chapter!!
thanks I downloaded the first program and it has done all the audio ac3 files (4 of them) but hasnt done the video file m2v?? its got a d2v file thats only smallOriginally Posted by stars
EDIT dont worry I had to save video!
so what is the d2v file for? -
GUI pops up somthing about framerates may not patch for PAL.. what do I do here?
ive got it opened but got no idea where to look to see if theres layer breaks?
This is a screen shot
Double-click on the PGC with the longest running time (1.20.08) Title 1
It will then open in a new window with details of chapter breaks and other information. -
ok it comes up with a lot of chapters but how do I know if their breaks?
Theres 25 chapters -
There's a table with a column of squares called "seam less joint". Each numbered chapter box should be ticked to indicate that they are indeed "seamless". If they aren't, you will have to tick them yourself. I had a similar problem with a different movie.
ah thanks very much none of them were ticked! I shall tick them all and see what happens now
Thanks alot for your help hopefully this is it! -
thought id post and let you know all is great and works perfect with no pauses! thanks very much for your help
Thanks for letting us know it worked as it could perhaps help someone else with the same problem
Player pauses
By Daijard in forum Software PlayingReplies: 8Last Post: 9th Feb 2010, 20:53 -
how to record without pauses
By mehrlicht in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Apr 2009, 16:00 -
Pauses between the chapters during playback
By roblobster in forum Authoring (DVD)Replies: 8Last Post: 8th Feb 2008, 22:54 -
divx pauses during playback
By poppinjay in forum Newbie / General discussionsReplies: 6Last Post: 8th Oct 2007, 19:41 -
Video backups contain pauses
By dadbackup in forum DVD RippingReplies: 10Last Post: 15th May 2007, 15:13
