    May 2006
    united kingdom
    You can now get lots of free TV
    streams from the internet
    which is great but I wonder is there
    any way that stream can go into some
    software that could say take caps
    or record short movies etc ?
    thanks for any comment
    vlc media player supports many streaming formats and you can save screenshot and also record using it. To record select File->Open Network Stream and under Advanced options click Stream/Save, click settings, select File and dump raw output.
    May 2006
    united kingdom
    THANK S
    it would be great to get the tv
    stream into vlc as then you can
    do caps while the tv is running etc
    but I go on the tv web site
    click on the channel and winamp starts
    up by default
    Just open the address in vlc.
    May 2006
    united kingdom
    NO I can t crack it
    it would be interesting to know if
    anyone has managed to get live, streaming tv
    to play in VLC
    and if they have , maybe they can give a step by step guide
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Give us an example
    Read my blog here.
    May 2006
    united kingdom
    for instance one of the tv channels
    from here
    http://wwitv.com/portal.htm
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The site you have given provides links to may different feeds from many sources. Some are just website links, some are real player files, some are asx files. I doubt you will find one applications that happily plays or captures all of these.
    Read my blog here.
