what causes this?i tried dvd architect,dvdauthorgui but i still get the errors,it is a mpeg2 converted from avi with winff
Results 1 to 9 of 9
Out by a constant amount, or does it drift out as the movies goes on ?
Out by a constant amount - determine the amount and add a delay to the audio to adjust. Common practice on commercial discs.
Drifts out over time - something got screwed up during the encoding.Read my blog here.
out by a constant amount,what if i demux?and then remux?an how do work out the amount of delay?
Load the video and audio into Media Player Classic, either as a program stream or as demuxed elementary streams. Set it playing, then use the + and - keys on your numeric keypad to vary the delay in real time until you get it lined up. Note the delay displayed at the bottom of the screen, and use this to adjust when authoring.
Read my blog here.
i tried to demux with DLP and batchdemux,batchdemux tells me the mpeg is not valid,dlp demuxes both but only shows me the mpeg stream no audio
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
CODECS-Too Many? Find and Clean-A/V sync Errors
By mrlewp in forum Software PlayingReplies: 9Last Post: 17th Apr 2008, 05:33 -
Sound Card - Cure for My Sync Errors ?
By mrlewp in forum AudioReplies: 13Last Post: 9th Apr 2008, 19:20
