i have vitrtual dub and got rid of logo in avi but the avi file is way... too big to complete is what can i do to make the file smaller size? or is there a better logo remover application?
When you save out of virtualdub you have to select a codec or you get uncompressed (read HUGE!) video files. Video -> Compression. Select and configure a codec, then save.
Read my blog here.
What was the original codec? You could use the same and increase the bitrate somewhat to make up for the encoding loss. VD will tell you some info about the original in 'File>File information'. But better is Gspot 2.70. It will give you quite a bit of info about your video.
best practices when using MSU logo remover with virtual dub
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2016, 01:22 -
MKV to AVI in Virtual Dub With AviSynth :?: :!:
By ineedhelp123 in forum Video ConversionReplies: 28Last Post: 21st Jul 2008, 15:08 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 20:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 16:21
