Hi,
Have a DVP5140 that's about 16 months old, it's had a resonable amount of use.
This weeks it's developed a fault where it has real trouble reading dual layer discs. It will take 2-5 minutes to load and another 2-5 minutes to change layer. This is accompanied by some strange hardware noises (it sounds nothing like skipping).
It will read single layer discs fine.
Has anybody else experienced this? Can anybody suggest some possible fixes?
Thanks in advance
Stu
Likely a hardware issue. Reading DL discs requires the unit to focus more accurately on each layer. You would also likely see issues on recordable media before commercial media. Aside from possibly a dirty lense, there isn't anything you can do to "fix" it. Repair shop if it's under warranty, replacement if not.
Google is your Friend
Philips DVP5140 Subtitle Recognition Question
By jeanpave in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st May 2010, 22:10 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
one problme about philips dvp5140
By raid168 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Feb 2008, 19:18 -
aspect cropping problems with the DVP5140/37
By stubish in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Aug 2007, 00:30 -
Experiencing problem with dvp5140
By mancalledhero in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Aug 2007, 21:10
