I have a WMV file that is the only known copy of a certain video. Unfortunately, the quality sucks. It's 320x240 with video bitrate of 300 kbps. Is there any sort of filter chain (maybe in VirtualDubMod after loading it via AVISynth?) that can de-block it enough to make it at least semi-presentable in converting it to DVD to view on a TV?
Thanks!
Why not just use Super to convert the clip to a VCD compliant mpeg (352*240 for 29.97fps or 352*288 for 25fps)
Import this straight into your dvd authoring program. Most (Ulead certainly) will not attempt to convert the video ferther and just change the audio frequency to 48 khz.
The result could well surprise you but it will depend in the size of your tv. -
Well, I've never worked with anything sub-VCD quality before. I'll try, though.
How to convert that like a High Quality WMV Video?
By iqbal88 in forum Video ConversionReplies: 1Last Post: 11th Mar 2012, 14:15 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 18:08 -
Can I convert Xvid to WMV without any loss of quality?
By sofakng in forum Video ConversionReplies: 7Last Post: 19th Jul 2007, 11:49 -
Convert DVDs to WMV files while Maintaining DVD 5.1 Audio and Video Quality
By JBredensteiner in forum DVD RippingReplies: 3Last Post: 18th May 2007, 18:58
