Results 1 to 11 of 11
    Aug 2006
    I have just burned a films onto a disk. It works fine on my playstaion and one of my dvd players but not my one. On my dvd player it says no disk after a while. Other backups that i have not done myself work on that dvd player but not my ones. I burn using nero 7. I even erased a disk that i knew worked, burned another film on it then it didn't work. What am i doing wrong? thanks
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Most likely explanation is media. Some players are picky about the types of media that they can read, not all media works in all players. Does the newly burned disc work in the other two players? If it does, then you will need to try a different brand/type of media in the problem player.
    Google is your Friend
    Aug 2006
    the newly burned disk works everywhere but my dvd player. What do you mean by changing the media?
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Use IMGBURN to burn your discs. Also find out the MEDIA ID of those discs that you're using. My bet is you're using cheap dvd media which will give playback problems. What is the brand of your dvd burner?
  5. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    In my opinion if you intend to keep what you have burned for some time, it is best not to use RW media.
    Some older DVDplayers will not read RW media, or only marginally detect them - perhaps working for a while then failing, or working intermittantly.
    Of course some older players do not like many brands of DVD+R and DVD-R as well.
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Where is everywhere (your PC does NOT count)?
    Changing the media means using A) a different brand...name brands are best such as Verbatim or TY B) use a different type +R or -R
    Aug 2006
    i will try imgburn and ill see what that does. What i mean by everywhere is playstation and other dvd players. Im burning avi files onto the disk could that be anything?
  8. Member oldandinthe way's Avatar
    Mar 2006
    If you are burning AVI files as a data disk it sure could matter.
    Many DVD players only play disks in DVD format.
    Aug 2006
    how do i know if its a data disk, its a sony dvd-r accucore?? Doesn't nero convert files
  10. Member oldandinthe way's Avatar
    Mar 2006
    Nero will burn both video disks and data disks.
    If you are not using Nerovision (or another authoring program) to reauthor into DVDvideo, but are just telling Nero to burn your AVI files, you are burning a data disk.
    If you use Explore to look at your DVD and see AVI files you have a data disk.
    If Explore shows a video and an audio directory and the video contains .vob files, you have a DVD-video disk.
  11. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Use CDBurnerXP Pro to burn AVI files. Nero sucks at burning data.
    http://www.cdburnerxp.se/download.php
    You'll need to have a standalone dvd player that can playback (divx) avi files. Not all brands of dvd players can do that.
