My network cameras and other networking hardware keeps instructing me to select different port numbers for various items, for security reasons. How do I know that a number I choose is not crucial for some other process or hardware?
For example I read somewhere that you can only use even numbers for some things - could be a bit of a gotchya there!
Thanks for any help!
Dean
ports in current use:
common ports and so ones to avoid if you are looking for "non crucial" ports:Code:netstat -an
http://www.iana.org/assignments/port-numbers
The Dynamic and/or Private Ports are those from 49152 through 65535SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Help with usb ports?
By t_jay17 in forum ComputerReplies: 5Last Post: 4th Feb 2009, 09:33 -
serial ports
By rubberman in forum ComputerReplies: 10Last Post: 17th Jan 2008, 11:40 -
Best way to get 4 to 6 USB ports, 30 feet away from my PC.
By Xenogear900 in forum ComputerReplies: 2Last Post: 7th Oct 2007, 20:00 -
engine or ports
By gunukhan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 31st Jul 2007, 13:48 -
USB ports or motherboard or both??
By tryintoo in forum ComputerReplies: 21Last Post: 10th Jun 2007, 13:15
