I am using Sony Vegas 6.0, and am wanting to creat quicktime MOV files for display on the web.
I was, for example, converting a 100MB video file into MOV and adjusted the dimensions to:
320x240
Quality: Preview 50%
32bpp color
NTSC
Audio uncompressed 44,100 16b
This creates a 1GB (!) file.
Why the perplexingly huge MOV file?
Because you didn't select an appropriate compression codec or you picked a high bitrate.
Uncompressed RGB32 at 320x240, 25 fps would be about 460 MB/min. Plus audio. -
There is a "video format" pull down box.
At the moment I have "None", but theres a whole list of them such as:
Animation
H.261
H.264
JPEG 2000
PHOTOJPG
Planar RGB
PNG
Sorensen
TGA
TIFF
etc etc
Which one is the best (for web)? -
Vegas makes a LOUSY H264 file
Use sorensen or get PREMIERE PRO or QUICKTIME PRO ($20) to make .H264
Captured video but what to do since file is huge.
By I26 in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2010, 20:19 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 16:40 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
Huge AVI file after mencoder encoding
By nickman00 in forum DVD RippingReplies: 3Last Post: 2nd Jun 2009, 19:57 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 08:32
