    Sep 2007
    Italy
    Hello
    I want to know is it possible to watch a not original movie with console.
    Some friend told to me that they can't read a dvd-copied on Xbox360 and PS3 only
    the original movie, is it correct?
    Is there someone that can do it?
    bye-bye
  2. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    i have played burnt dvds on the 360 fine
    Sep 2007
    Italy
    Without any hardware modification?
    Dec 2006
    Canada
    I really don't think you can without modification.
    I use TVersity and play it direct from my computer. It plays great on both the 360 and PS3. Any files divx, wmv, mpeg, vob etc. All without conversion.
    The only disadvantage with the 369 you cannot FF and RW and resume.
    On the PS3 you can do anything.
    Its better than a DVD Player.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    He was referring to the ability to play burned/copied dvd's on the 360 without any modification.
    Google is your Friend
