My Sony Handycam DVD508's only input is USB. Is there a RCA to USB converter?
USB is purely digital, RCA is analogue. You would need some form of digitiser in between to convert the signals. I don't believe such a beasty exists cheaply. RCA-USB does exist for encoding for the PC, but you can't use these to get video into your camera.
Read my blog here.
Pinnacle makes a USB "Moviebox" that will take analog input, like from a VHS VCR for instance, and output it via a USB cable, which you can connect to your PC. They are not terribly expensive.
The only issue would be detecting it with anything other than the Pinnacle Studio software that comes with the hardware. I am not sure if the signal is encoded/encrypted so that only Pinnacle Studio can see it, or not. It would be possible to hack this, if necessary, on a PC, but with a camcorder as the recipient...
RCA 42 inch RCA LED42A45RQ - Horrible Sound.
By HoosierGuy in forum DVB / IPTVReplies: 10Last Post: 13th Dec 2011, 20:23 -
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
RCA (from a VCR) to usb?
By celchlepp in forum Video ConversionReplies: 9Last Post: 6th Apr 2010, 18:06 -
can receive feedfrom rca leads but not via scart to rca lead
By deanno in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2009, 10:39 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 10:06
