Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
  1. Originally Posted by forare
    dear manono
    did you try to play my vob in vlc ? set it to deinterlace and you will see
    like a double edge all over . This is ecxactly how i see it on my standalone,
    I played it on onother box and excatly the same so i think my player is not deinterlacing something else is wrong
    Are you watching on a progressive display - a widescreen television set? If so, then your player or TV set does a horrible job of deinterlacing it. If the player is set for progressive scan, you might try outputting 480i instead and having the TV set deinterlace it to see if it looks any better. If you're watching on a regular interlaced TV set, then you shouldn't see any blends or double images at all. Maybe I'm missing something, I don't know, but that VOB looked normal to me.
  2. Member MysticE's Avatar
    Nov 2003
    I just took the VOB and ran it through NVE3 (it did not re-encode) and then MPEG Video Wizard DVD (it also did not re-encode). Both played correctly with my JVC player on my Panasonic 32" CRT (via S-Video).
  3. Thanks, MysticE. I was thinking of making a little MiniDVD out of it for testing on my standalone, but was lazy. You confirmed what I suspected to be true. That still doesn't solve forare's problem, though. I can maybe explain the problem if he's using a widescreen TV set. I can't explain it if he's using a regular old interlaced CRT set. Unless - unless this VOB isn't from the final DVD he created for playing on his standalone.
