I checked an earlier forum post and downloaded FLV metadata injector but that didn't work on the file. I had nothing checked in the metadata injector GUI so I don't know if that affected the injection. Any ideas?
Some files aren't properly indexed or the indexing is corrupt (also occurs in asf/wmv/avi files), which results in the file being unseekable. Quite often, the fix is to simply open the file with an editing tool (that supports the file type you are having trouble) and simply saving a new copy. I haven't done this with flv files, but it should apply.
Google is your Friend -
Most FLV files is not seekable in VLC.
I'm check many different FLV's and always not seekable in VLC.
However - no problem in SMPlayer, Media Player Classic (FLV Splitter build-in), The KMPlayer and DirectShow players when used FLV Splitter (Gabest).
MiniDV passthrough shows video only when fast forwarding
By LSchafroth in forum Capturing and VCRReplies: 12Last Post: 14th Jun 2010, 20:51 -
Fast forwarding and rewinding a tape before capture?
By justin81 in forum RestorationReplies: 4Last Post: 14th May 2010, 17:41 -
Video freezing when fast-forwarding.
By xcodyj in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 04:45 -
Viewing during VCR fast forwarding/rewinding
By spinmonk in forum Capturing and VCRReplies: 12Last Post: 30th Aug 2009, 19:30 -
ogm's fast forwarding
By CommanderZero in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2007, 00:23
