    Sep 2007
    I'm working with a local cable station that uses Tightrope's Cablecast, and has had multiple DVD import errors on DVD's I provide. During import, around 25-35%, it will stop with "Error: Data error (Cyclic Redundancy Check)".
    They seem to have to have errors only with my discs. After review, it appears to be a compatibility issue of some type. The original HP burner in our Video PC seems to be the common thread on the errors. These same discs have no issues at 2 other cable stations that run them on players, or on any PC or consumer player I try them on. I wanted to provide some background to see if anything else may be worthwhile considering.
    DVD-R Media tried: Fujifilm 8X inkjet printable, TDK, and most recently Taiyo Yuden 8X inkjet printable (premium line).
    Authoring Tool: Sony DVD Architect 3.0
    Burners:
    "HP" DVD Writer 640b FW223, ATAPI
    "LG" HL-DT-ST DVDRAM GSA-H10L FW LL12 ATAPI
    The cable station's PC's are using Pioneer DVR-111D drives. I plan to swap the HP burner with a Pioneer to eliminate any future issues. Are there other items I should be checking?
    thank you
    Bob Langlois
    Trinity Assembly of God Video Director
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sounds like typical burning issues which could be the result of media (bad media or media incompatibility) or fautly hardware.
    Google is your Friend
