hi. i'm new to all of this, but the program has been easy to use. i've already burned a couple of great dvds.
However, i renamed my movie files and put them in different folders and all that to get them organized. Well, now my saved project can't find them and won't open. I've tried guessing at the file names and folder name, but none of it worked. is there a way to reconnect the .s2d file with the movies? I'd prefer not to have to start over on this project.
thanks
jeffc4442
Only if you rename them and move them back.
Honestly, you didn't expect it to work after you effectively hid everything from it did you?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
you would have to edit the project file by hand and point the assets parts to the new locations
Thanks, Chrissyboy, but what do i need to do to alter the file by hand. i've dug around, but no luck so far. thank you for your help!
In your saved project (.s2d file) you should have something like:
just change the Path="G:\films" Filename="part1.mpg" bits to point to your new locationsCode:.... <Asset ID="26b03595-98ea-4da5-988d-8869a0f18735" Path="G:\films" Filename="part1.mpg" /> <Asset ID="1a809833-3a21-46ac-b280-db9f4418d3a4" Path="G:\films" Filename="part2.mpg" /> <Asset ID="5b6b75c4-ae1f-4d2e-83f6-827f95ba57d7" Path="G:\films" Filename="part3.mpg" /> ....
ok. Start notepad. Then drag & drop the .s2d file onto it.
Failed to load subtitles
By Basd in forum SubtitleReplies: 1Last Post: 7th Oct 2011, 17:06 -
"Device not ready, medium may have changed"
By mobie29 in forum MediaReplies: 0Last Post: 20th Jan 2010, 23:46 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 15:29 -
dvdauthor problem "chapter doesn't exist"
By ecc in forum Authoring (DVD)Replies: 2Last Post: 28th Jan 2008, 09:54 -
AutoMKV problem, warpsharp.dll failed to load
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 09:32
