Well, I'm attempting to convert some H.264 AVI files into Divx AVI files but I'm having some serious issues. Yes I have the codecs, and no I'm not setting it up wrong. Basically everything I try makes the converted file no bigger than 14.4MB, from a 250MB compressed source file, and many make it under 10MB. I've confused. I'm using Virtual Dub, latest version, for the conversions. Any ideas?
Do you see the picture in VirtualDub's source window? Is there video in your output file?
General procedure:
File -> Open Video File
Video -> Fast Recompress
Video -> Compression (select Divx and parameters, try 1-pass-quality-based, fixed quantizer 3)
File -> Save as AVI. -
EDIT: Well nvm, just tried some different settings and it worked. Went back and tried my old settings and even that is working now. I have no idea what happened, but at least it's fixed. Very weird.
EDIT EDIT: Think I figured out what it was. When I tried it a minute ago I wasn't trimming the file and the output file size seemed normal. Second I added some trimming to it, it went back to being messed up. Ohh well.
Problems with converting mkv(h. 264) to avi
By sgbd in forum Video ConversionReplies: 7Last Post: 18th Nov 2010, 11:10 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
having problems in converting from h.264 to avi
By the deadman in forum Video ConversionReplies: 3Last Post: 18th Nov 2007, 10:08 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 09:25 -
help with converting avi to h.264
By greymammoth in forum ffmpegX general discussionReplies: 0Last Post: 13th May 2007, 16:18
