Is there a way to make the Xbox 360 Media Center Extender play DivX files?
I know there is a way to play them without using the Media Center interface - but I'm looking for a way to play them inside Media Center.
My media center PC is running Vista.
I use Transcode 360 to play divx files from my computer to my 360 through windows media center, there is a rumour that the fall dashboard update for the 360 will add divx support, hopefully it will happen.
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Embedding .SRT to .AVi (divX/XVid) for Xbox 360
By Alereon in forum MacReplies: 7Last Post: 14th Oct 2009, 11:00 -
Xbox 360 Fall Update Official Details Revealed, Adds DivX Support
By MJA in forum Latest Video NewsReplies: 6Last Post: 6th Dec 2007, 09:58 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06 -
XBox 360 - XVID / DIVX support?
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2007, 20:11
