  1. I have tried and tried to install SVCD2DVDv2.5 on XP but it will not install because netframework just crashes then quits.
    I have tried to download v2.0 but links are dead
    any ideas please.
    ps. I am a reg'd user
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Any more info? error screenshot?
  3. The following properties have been set:
    Property: [AdminUser] = true {boolean}
    Property: [ProcessorArchitecture] = Intel {string}
    Property: [VersionNT] = 5.1.2 {version}
    Running checks for package '.NET Framework 2.0', phase BuildList
    Running external check with command line "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSDD0.tmp\dotn etfx\dotnetchk.exe"
    Process exited with code 0
    Setting value '0 {int}' for property 'DotNetInstalled'
    Reading value 'Version' of registry key 'HKLM\Software\Microsoft\Internet Explorer'
    Read string value '7.0.5730.11'
    Setting value '7.0.5730.11 {string}' for property 'IEVersion'
    The following properties have been set for package '.NET Framework 2.0':
    Property: [DotNetInstalled] = 0 {int}
    Property: [IEVersion] = 7.0.5730.11 {string}
    Running checks for command 'dotnetfx\instmsia.exe'
    Result of running operator 'ValueExists' on property 'VersionNT': true
    Result of checks for command 'dotnetfx\instmsia.exe' is 'Bypass'
    Running checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe'
    Result of running operator 'ValueExists' on property 'Version9x': false
    Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.0.3': false
    Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.0': true
    Result of checks for command 'dotnetfx\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
    Running checks for command 'dotnetfx\dotnetfx.exe'
    Result of running operator 'ValueNotEqualTo' on property 'DotNetInstalled' and value '0': false
    Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false
    Skipping FailIf because Property 'Version9X' was not defined
    Result of running operator 'ValueNotExists' on property 'IEVersion': false
    Result of running operator 'VersionLessThan' on property 'IEVersion' and value '5.01': false
    Result of running operator 'ValueNotEqualTo' on property 'ProcessorArchitecture' and value 'Intel': false
    Result of checks for command 'dotnetfx\dotnetfx.exe' is 'Install'
    '.NET Framework 2.0' RunCheck result: Install Needed
    EULA for components '.NET Framework 2.0' was accepted.
    Copying files to temporary directory "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSDD0.tmp\ "
    Downloading files to "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSDD0.tmp\ "
    (19/09/2007 20:50:29) Downloading 'dotnetfx\dotnetfx.exe' from 'http://go.microsoft.com/fwlink/?LinkId=37283' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSDD0.tmp\'
    Download completed at 19/09/2007 20:50:53
    Verifying file integrity of C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSDD0.tmp\dotne tfx\dotnetfx.exe
    WinVerifyTrust returned 0
    File trusted
    Running checks for package '.NET Framework 2.0', phase BeforePackage
    File trusted
    Installing using command line '"C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSDD0.tmp\dot netfx\dotnetfx.exe" /q:a /c:"install /q /l"'
    Process exited with code 1603
    Status of package '.NET Framework 2.0' after install is 'InstallFailed'
  4. Can you upload SVCD2DVD v2.1 again m8 as I am getting a 404 with firefox
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    if you email me i will see if i can dig out an old version for you
