Ok, I've been trying to do this for some time and I still end up coming out on thw wrong side of bad.
Let me fill you in...
The other day I witnessed a movie that was compressed with Xvid and they had the entire movie down to like 700MB. But it still looked AMAZING!!!!!!
Whenever I try and do something like that, my file still ends up to be 4 to 5 times that sized and the quality is garbage compared to that 700MB file.
GRRRR!!!!!!
I have neer been able to get a 22 minute TV show that I recorded in high def to look anywhere nears as good as the groups seem to release with file sizes of only 200MB.
What am I doing wrong?
Please help.
	Another way you can do this is to use Fairuse Wizard. Set it for 2-pass encoding with the file size set to 700MB (or whatever you want). 700MB is commonly used only because at 700 MB it will fit on a CD. You can experiment with the file size to get the best combination of quality versus file size as you wish.
	there are lots of reasons they look so good.. one is that the ones that do look great are off a digital master with 6 pass encoding mp3 sound if you want ac3 the files are usually 2x700 or should i say 6 channel sound. if you try to cap with a video cap card cap in avi raw best settings for the source then re encode to xvid multi pass you will get the same results.
  NovaMate NovaTrol 2 TBC - How the heck do I use it??By jbd5010 in forum Capturing and VCRReplies: 4Last Post: 3rd Feb 2012, 17:04
  What the heck is Unreferenced Material ? ? ?By nhbfan12345 in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2008, 17:01
  How the heck did they do that SuperBowl eTrade ad?By ahhaa in forum ComputerReplies: 6Last Post: 5th Feb 2008, 17:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
