My burner is an LG GSA-4040B. For some reason it only burns dvd's at 2X instead of 4x. I recently updated the firmware but I still can't burn at 4X. Nero infotool gives the following information:
Under the drive tab
Drive read speed: 8x
Drive write speed: 2x
Under the disc tab
Supported speed: 2x
Ok, perhaps the ritek G05 discs I'm using don't work well with this drive even though the discs say 8X on them. I haven't actually tried any other dvd discs. But my question is this: Why does the DRIVE write speed claim only 2X? I mean it's a 4x burner. Is it possible there's something wrong with the drive?
Btw I have the drive installed as master on the secondary IDE bus as per the firmware update instructions.
There are a number of forum reviews on this page https://www.videohelp.com/dvdwriters/lg-gca-4040n/94
"Crap" seems to be the operative term used. Older drives often have a problem with newer media. Good burners such as the Pioneer 112 cost well under forty dollars. It's not worth messing around with a drive like this. My standard advise is; Invite a few friends over and say a few kind words of remembrance over your pathetic LG burner and bury it and take it - and you out of its misery. -
It's not helping at all that you are using Ritek discs, which are crap. Do yourself a favor and look at:
http://www.nomorecoasters.com
We had another post today I think from a guy who was crying because his Ritek DVDs are now going bad. So the combo of poor discs and an old, crummy DVD burner are to blame. -
alright thanks.
I guess I'll just try another brand of DVD's, if that still doesn't work then i'll get a new drive. 25 minutes for a DVD to burn is unacceptable in this day and age. -
LOL...I remember waiting 45 minutes for CD's to burn.Originally Posted by mr-scarfaceGoogle is your Friend
How can I increase DVD/Blu ray write speed?
By gsingh13 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2011, 22:47 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 02:40 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 06:49 -
Write problem with FH-16AYH burner on Memorex DVD+R DL
By hibbs in forum DVD & Blu-ray WritersReplies: 12Last Post: 4th Jan 2008, 04:30 -
DVD burner doesn't write anymore
By mr-scarface in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Aug 2007, 23:18
