Hello.
I wont to know if xbox 360 and PS3 can read
the dvd movie ripped and copied on dvd-r/+r dvd-rw dvd-duallayer....
Is it possible to connect a HarDisk on usb port and watch the movies in VOB format?
I'm searching a dvd player that can read all the format and it let me connect a HD on usb port
for watch the movie ripped on it in VOB format.
thanks
sorry for my english
VOB isn't a video format as such - it's just a part of a Video DVD taken out of context, and was/is not meant to be played as a file at all. If you for some reason have VOBs with no Video DVD structure (.ifo, .bup & cetera) extract the mpg out of the VOB with VOB2MPG. But i doubt neither xbox nor PS3 will play it without running some media center software (=hacked/modded hardware). The chances are much better with a complete DVD-bacjup on DVD-R.
/Mats -
Hello
I want to know :
-Is there a dvd player that it can read vob file from HD external?
I'm looking for this because when i copy the dvd movie i used to ripped it on PC (so i have vob file).
Any-dvd made 2 folder AUDIO and VIDEO, in VIDEO i have all vob file.
So instead to copy the files on dvd i want to use the hd and connect it on a dvd-player with usb port.
I prefer don't make any modification to the file that any-dvd done....
I think the only solution for me is a media-centre isn' it?
I think about xbox360 o ps3, but some friend told to me that they can't read a dvd-copied on these machine only
the original movie, is it correct? Or someone can do it?
The dvd players that have the usb port can solve my problem?
bye-bye -
My std DVD player reads (and plays) VOBs if I write them as data files on a CD or DVD, so I'd guess there are DVD players with USB ports that'd do the same with VOBs on HDD.
But I see one problem - A movie can be made up of up to 8 or 9 VOB files - you won't get contionous playback of a whole movie if you go by it as you intend - or does AnyDVD merge all VOBs into one? If so, they have to be <= 4 GB alltogether, as the HDD has to be FAT32 formatted (and FAT32 can't handle files > 4 GB).
/Mats -
Your friends are talking nonsense ...
Verbatim dvd+dl currently running on xbox360 fine .
Ps2 slim , fine
Ps2 old , some issues
Ps3 ... better ask someone with one .
External hard drives must have there own power supply , and be formatted using fat32 .
Xbox360 , using external hard drives , abilities restricted to pictures and music , not video . -
My HD is FAT32 and i copy the dvd without any compression so the entair folder is about 5 o 6Gb but every single file vob are max 1 or 2 GB.
The problem for the FAT32 is file superior to 4 GB but is not my case...
Do you know any good player with usb port?
8gb ps3 vob file to 2 dvd?
By conjure in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2010, 03:15 -
!! file that works with iPhone, PS3 and Xbox360 and Computer !!
By BR4INsick in forum DVD RippingReplies: 4Last Post: 9th Dec 2009, 19:09 -
Steam DVd folders from PC to Ps3/xbox360
By pcexpress911 in forum Media Center PC / MediaCentersReplies: 20Last Post: 13th Feb 2009, 04:10 -
Can Sony PS3 system play copied DVD movie?
By coody in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2009, 01:33 -
PS3 XBOX360 whit not originl movie dvd
By MOPLASMA in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Sep 2007, 13:10
