there is an option to create HD DVD formatted disks using an existing DVD burner...the pack that allows you to do this is a $49.99 addon...
You Have Selected:
Premium Features: HD Authoring Pack 1.0
Price: $ 49.99
Make High-Definition HD DVD format movie discs, complete with HD motion menus, that play on the Toshiba HD-A1, HD-XA1, and HD-D1 HD DVD players and display on your HD TV. Use the standard DVD burner you have today to
burn HD DVD format discs straight to standard DVD media.
I have two questions:
1. is this any good? (assuming someone here has used it)..
2. Will these disks work on xbox 360 addon??
TIA for any help on this...
This is only useful if you are importing HD video, from either a camcorder or from a HD PVR or from a HD Tuner capture card. I own Pinnacle's software, and it has never completed a successful encode without halting with an error, and I have tried this on three different machines, including a newish Pentium D/Vista/3GB/Nvidia GT8500/ system. Still no go.
A good idea in theory, but the software is still buggy, although I have only tried HD sources from my Motorola PVR captured via firewire, it may be better with other, perhaps more standard HD material.
I would look instead at the new version of Nero 8, and see if the HD-DVD authoring includes the option to burn to a DVD-R. Ulead also has software that claims to be able to do this.
adcvideo -
I have been using Studio since ver 8 and have not had any problems...I have a canon hv20 (that thing is awesome) and have no problems importing my footage in high def and then burning it to a DVD. It just sucks seeing the difference between the DVD and the minDVD footage so I really want to look into being able to burn an HD DVD...using my existing burner would make this decision a no-brainer...Originally Posted by adcvideo
Guess I will bite the bullet and pay the $50 to see if it works out for me.../crosses fingers now...
PINNACLE STUDIO 11 - dvd no audio plays
By ancient in forum Authoring (DVD)Replies: 2Last Post: 10th Jan 2012, 09:07 -
Pinnacle Studio DVD conversion help!
By dberlener in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2010, 17:16 -
Pinnacle studio 14 problem with DVD export
By Alternator in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2010, 22:22 -
How to Capture VHS-C Tapes for Editing/Authoring with Pinnacle Studio
By saroman in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2010, 22:48 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53
