hi I have the bluetinum BT-TTU305B , which in XP uses the Empia USB 2821 drivers .
however - I cannot find any drivers for Vista - any one know where to get generic (or something) drivers for a device which uses this chipset ?
I use Honestech TV 3.0 plus as capture software (was with the device)
but it constants keeps crashing in vista - and the audio driver for the capture card (and the video I suppose) isnt installed
HELP
This may not work, but did you try installing the driver using XP SP2 Compatibility mode? I got a HDTV card working that way and it didn't have any Vista drivers available. I also temporarily turned off UAC when I loaded the drivers and software. Not sure how much that helped, but it did get rid of some of the warnings. Now everything but the infrared remote receiver works. But I didn't use that anyway. Might be worth a try.
And welcome to our forums.
I will try this.. I am complete new to Vista...
but bluetinum says no vista support.. but I think Pinnacle has an USB with empia 2821 for vista.... -
tried this, can get video on honestech TVR 2.0 and XP drivers - but no sound...
XP SP2 mode is activated by right clicking on the Exe file and choosing XP SP2 compability ...? -
The XP SP2 compatibility mode is in 'Properties' when you right click the driver. My HDTV card is running perfect with no Vista drivers available. During the install, Vista gives a lot of warnings and says it's not the right driver, but it still works.
In regular mode, it wouldn't let me do the install at all.
Be aware that audio is handled much different in Vista than earlier OS's. You may have to play with the settings a fair amount to get it working, if it will work at all. Vista uses mostly software for audio, so some audio cards won't work with it. But because it's software, there should be more flexibility with the settings. -
hmm, I am not getting any possibility to choose xp sp2 mode on the driver (.INF)..... Guess I will try to get the free lenovo "downgrade" to XP CD....
Sorry, you can't choose XP SP2 mode to install or run .inf files.
I think that only works for .exe files or files that have an installer program.
Vista Drivers for This Computer - Help, Please!
By jeanpave in forum ComputerReplies: 16Last Post: 27th Oct 2011, 05:22 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Vista modem drivers.
By Poppa_Meth in forum ComputerReplies: 5Last Post: 1st Nov 2007, 11:32 -
Looking for some Vista drivers
By t_jay17 in forum ComputerReplies: 3Last Post: 9th Oct 2007, 03:29 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
