I came into a project halfway through and I have a question. My source video I'm importing to edit in Pro is .m2p. After I've done all the editing, I'm ready to export it. The eventual destination is on a DVD. Is there any way to know what field order I should use? Or should I deinterlace? I usually just go to bottom field first on DV, but I don't know which to use when an MPEG2 is my source.
Any help would be greatly appreciated.
Also, would it be beneficial to export to .AVI or not. I'm just going to take it into Encore to make a DVD.
Thanks,
Joey
Use G-Spot to figure the source field order. The project setting should match but so long as the encode matches the source Premiere Pro usually gets the video right but graphics inserts may jump around.
What is the M2p source? Are you certain it is interlace and not progressive? -
Then use BFF for project and encoder settings.
http://www.kiva.org/about
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Adobe Premiere pro CS3 to DVD using MP4
By Fary4u in forum Video ConversionReplies: 1Last Post: 13th Jul 2009, 13:13 -
Premiere Pro CS3 DVD items
By kippard in forum Authoring (DVD)Replies: 10Last Post: 13th Oct 2008, 15:24 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 08:54
