I have a Raw DVI file (wedding from 2 vhs tapes 5 hrs 10 mins total) file That I would like to put onto a Verbatim DVD+R DL
How do I go about encoding this down to 8.5GB, (videots) and what program is good for this.
Also LAYER BREAKS My Raw DV file has none, How can i add this to the encoding process
I want to use DL DVD as i have a few
I am really simple when it comes to Video Editing, and don't know where to start![]()
zack
What burning program do you have? If you have Nero, just have a play with the 'Make you own DVD video' feature.
Failing that, convert the DV to mpeg2 with TMPGEnc and then author to DVD with TMPGEnc Author.
Both programs have free trials.
p.s. I'm not sure if you meant layer breaks or chapters - don't worry about layer breaks, you can sort out chapters with TMPGEnc Author.Regards,
Rob -
Thanks for the response
My Raw DV video does'nt have any chapters or menus, I just want the DVD to run the full 5 hrs from when i put the DVD in the Player to the end
Straight DV to DVD9 transfer (no music, flashy intros or menu's)
But I must have the Layer break somewhere, so that the laser can adjust itself for the second layer on the DVD9 -
That will be done by the burning software.Originally Posted by zack28Regards,
Rob
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 03:35 -
VOB2MPG-PRO: Problem extracting VOBs from Verbatim DVD+R Dual Layer (8.5GB)
By rickyp513 in forum DVD RippingReplies: 1Last Post: 25th Aug 2010, 17:47 -
Newegg has Verbatim 8.5GB 2.4X DVD+R DL 20 Packs (95310) for $20 w/Free Shi
By Denvers Dawgs in forum MediaReplies: 37Last Post: 17th Dec 2009, 22:07 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
How to shrink the file size of 7.63GB after ripping the DVD?
By coy228 in forum MacReplies: 6Last Post: 16th Jun 2009, 10:19
