    Sep 2007
    Canada
    I've been using this program for years now with zero problems and I tried to start the program (v2.1) today and it froze as it was loading then after about 30 seconds the program closed. So I reinstalled that version as well as the v2.5 version and neither work, they both freeze as its loading. I have net. 2.0 and I'm on winxp. I never ran across this before.
    Any suggestions?
    Sep 2007
    I have the same issue here is the log.
    Version: SVCD2DVD 2.5
    Build: 2.5.3200.0
    Type: System.IO.FileNotFoundException
    Source: System.Windows.Forms
    Message: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    InnerException:
    StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
    at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
    at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
    at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
    at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
    at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    shab92: This should sort you out: https://forum.videohelp.com/topic334156.html?highlight=unsafenativemethods
    darrenp76: Drop me an email and we can try manually registering you...
