I recorded a program using Virtual dub
Capture settings:
FPS= 25
Video Compression: Yes - XVID (700 Kbps)
Audio Compression: Yes - MP3 (128 Kbps)
Format: AVI
when i play the AVI file its working perfectly fine no audio sync problem what so ever but when i convert it to WMV the audio is not sync'd.
WMV setting:
Video: 350+ Kbps
Audio: 64 Kbps
Is there a way to fix that?
What did you use to convert it? Try using windows movie maker if you have winxp or later.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
how to capture encrpted WMV file while playing
By steevo in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2010, 14:32 -
DV Capture to WMV encode. Looking for some advice.
By silmarallion in forum Newbie / General discussionsReplies: 10Last Post: 19th Aug 2008, 18:02 -
How to capture wmv
By drstew in forum Newbie / General discussionsReplies: 2Last Post: 15th Dec 2007, 13:33 -
WMV Format Capture
By zerohash in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 09:48
