Hi. I have some ISOs that I would like to burn to DVDs and watch on my PS2/DVD Player, but when I tried this, I got the message "TV system does not match." Which, as far as I have been able to find out, means that the videos are PAL format.
How can I convert the ISOs to NTSC, without losing quality? I can handle losing the menus, if necessary, but I'd prefer to keep them, if possible.
Thanks.
Lots of ways: https://www.videohelp.com/convert#4;41 It's not so simple keeping the menus, though.
The 'Patch' method may be the easiest if you don't mind losing the menus. You will likely have to extract the files out of the ISO first. I use ISOBuster most times.
You can play the ISO back on a computer as is. VLC Media Player works well for that. And you should be able to check the framerate then or Gspot may be able to check the ISO for 25fps rate that tells you it's a PAL format.
Help with converting Panasonic Lumix video files NTSC US system to PAL
By bodrilla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2011, 08:52 -
.iso NTSC to PAL with subs
By LoveMyslf in forum Video ConversionReplies: 17Last Post: 12th Jun 2008, 12:01 -
Converting PAL video to NTSC through SUPER
By DJL82 in forum Video ConversionReplies: 14Last Post: 3rd Jan 2008, 05:23 -
DVD ISO, PAL to NTSC help
By hiro24 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 02:17 -
converting PAL AVIs into NTSC DVD
By exekutive in forum ffmpegX general discussionReplies: 0Last Post: 24th Jun 2007, 19:20
