I haven't really found a definitive answer on how to fix this error in an .avi. When I run through avidemux, it will just put the audio out of sync where the error was... and if I use ffmpeg, here is the output where the hiccup is in the file.
I am still a little new at this and working with this, sorryCode:[msmpeg4 @ 0xb7e50768] error while decoding block: 20 x 6 (3) [msmpeg4 @ 0xb7e50768]Error at MB: 242 [msmpeg4 @ 0xb7e50768]concealing 2147483647 errors [msmpeg4 @ 0xb7e50768]error, slice code was 0 [msmpeg4 @ 0xb7e50768]header damaged Error while decoding stream #0.0 [msmpeg4 @ 0xb7e50768]ac-tex damaged at 13 4 [msmpeg4 @ 0xb7e50768] error while decoding block: 13 x 4 (1) [msmpeg4 @ 0xb7e50768]Error at MB: 161 [msmpeg4 @ 0xb7e50768]concealing 2147483647 errors [msmpeg4 @ 0xb7e50768]invalid picture type [msmpeg4 @ 0xb7e50768]header damaged Error while decoding stream #0.0 [msmpeg4 @ 0xb7e50768]invalid picture type0.9 bitrate=4989.3kbits/s [msmpeg4 @ 0xb7e50768]header damaged Error while decoding stream #0.0 frame=89277 q=2.0 Lsize= 2174884kB time=3570.9 bitrate=4989.4kbits/s video:1951840kB audio:195284kB global headers:0kB muxing overhead 1.292892%... I am trying to convert a divx to a dvd complient mpeg for burning.
Thanks in advance,
Kris
I can't use it due to it needing wxwidgets 2.8 (I have 2.6)... there is no easy way for me to upgrade wxwidgets in my distro without throwing everything out of whack, so I think I might be stuck. Is there any other program or command that might do the same thing?
I tried the original DivFix, but it always segfaults... -
I ended up using the win32 version in Wine, using the NT 4.0 setting... You can't scan for errors (crashes the program), but fixing errors works fine.
Thanks for the suggestion!
Fix bad avi file
By TBoneit in forum Video ConversionReplies: 8Last Post: 4th Oct 2011, 12:17 -
AVI broken header file
By magillagorilla in forum RestorationReplies: 3Last Post: 23rd Sep 2011, 10:01 -
Creating a header with only the data segment of a AVI file
By Hasindu in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:28 -
How to fix/repair a AVI video without a header?
By BlooderButcher in forum RestorationReplies: 4Last Post: 2nd Dec 2007, 11:42 -
Editing Avi header file and playing time.
By Abrus in forum Video ConversionReplies: 2Last Post: 12th Jul 2007, 11:48
