OMG!! i was so happy when i have succeded in compressing my big file video(i'm using autogk). however, when i upload it on youtube my video was being rejected. i guess it might because of the video format. so, i try to convert it to mpg. in the end my video size was increased...OMG!!! can someone help me to fix it??? thnx..
				Results 1 to 12 of 12
	I use Riva FLV Encoder or DivX/Xvid for YouTube. Never had a video rejected.
	General #0
 Complete name : D:\experiment\(Asian4Ever_1.avi.001
 Format : AVI
 Format/Family : RIFF
 File size : 49.9 MiB
 PlayTime : 42mn 50s
 Bit rate : 642 Kbps
 Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
 Writing library : VirtualDubMod build 2178/release
 Video #0
 Codec : XviD
 Codec/Family : MPEG-4
 Codec/Info : XviD project
 Codec settings/Packe : No
 Codec settings/BVOP : Yes
 Codec settings/QPel : No
 Codec settings/GMC : 0
 Codec settings/Matri : Custom
 PlayTime : 42mn 50s
 Bit rate : 523 Kbps
 Width : 320 pixels
 Height : 192 pixels
 Aspect ratio : 1.667
 Frame rate : 29.970 fps
	what kind of file does the Rive FLV encoder accept? it seems like doesn't work with Avi or mpeg.
	Keep trying. I've never had problems with Riva accepting either....especially mpeg.Originally Posted by sharmine
 http://www.rivavx.com/?encoderRiva FLV Encoder
 Transcode your existing videofiles to the advanced Flash Video (FLV) format with this free Riva FLV Encoder.
 After selecting a source-file you can easily transcode it into Flash Video using one of the presets or your custom settings.
 To view the result Riva FLV Encoder comes with the free Riva FLV Player.
 If you want to tell a friend, just pass this Link: www.rivavx.de?encoder
 At present you can transcode the following formats: AVI, MPEG, Quicktime, WMV.
	how do you split the file? how long is the playtime if you play it in a software player?
	when i play the first video that i have split..it doesn't show any play time at all..
 i tried my second video, even worse...it doesn't play at all..
 this is the mediainfo from my second video..
 Complete name : D:\experiment\AVSEQ03.AVI.002
 File size : 90.0 MiB
 Codec : MPEG-4 Visual
 Codec settings/BVOP : No
 Codec settings/Matri : Default
 Width : 352 pixels
 Height : 288 pixels
 Aspect ratio : 1.222
 Frame rate : 25.000 fps
 Resolution : 8 bits
 Chroma : 4:2:0
 Interlacement : Progressive
 Writing library : ZJMedia MPEG Encoder
 i guess, when i split my video, it doesn't split the play time as well..
 do you have any idea on what's happening?
  Is this the highest possible quality for YouTube? YouTube compresses video?By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 12:33
  Uploading a video to Youtube that will fill the ENTIRE youtube player.By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 14:40
  Converting a dvd vob to a high quality compressed file.. for youtube.By powrtoch in forum Video ConversionReplies: 3Last Post: 28th Nov 2009, 05:24
  Why won't YouTube convert a video that was downloaded from YouTube?By brassplyer in forum Video Streaming DownloadingReplies: 0Last Post: 5th Dec 2008, 05:47
  Ridiculous problem with Youtube (rejected video)By stranno in forum Video Streaming DownloadingReplies: 3Last Post: 27th Oct 2008, 01:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
